36 pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2011, 04:54 PM
36 pickup
On my 36 I want to use chevy wheels and brakes on the original ford axle. My Speedway catalog lists spindle kits and king pin sets.
Do I just order the 28 to 48 spindle set which comes with king pins and ford spindles then get adapters to put Chevy rotors and brakes on it?
Old 09-30-2011, 08:31 PM
BOBCRMAN@aol.com's Avatar
Use the 37 and later pin kit and spindle. The spindle will fit the 36 axle with an added shim/spacer. Then use the part no. 910-31945 for all the needed disc brake parts.
I usually use the 78-later calipers on most of my conversions. They are plentiful, easy to adapt and inexpensive.
Old 09-30-2011, 11:26 PM
36 pickupI will get those parts as quickly as I can
Thanks bobcrman, I will get those parts as quickly as I can. I'm anxious to see some progress on my rod.
84 toyota 4x4 pickup, 91 s-10 2wd pickup, leaf pack distance? fast68 Hotrodding Basics 1 10-07-2010 12:40 AM
Clip 552nd Pickup With 78 Chev Pickup JFK55BOY Suspension - Brakes - Steering 2 05-03-2007 08:33 PM
s-15 pickup gmc alnat Hotrodders' Lounge 3 04-06-2007 11:17 AM
My 74 Pickup 74-Chevy Introduce Yourself 1 11-23-2005 07:11 AM
1932 Ford Pickup and 1933-34 Pickup Different? YES pasadenahotrod Transmission - Rearend 1 10-23-2002 02:20 PM
