36 plymouth steering shaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2011, 02:37 PM
I would like to get an aftermarket steering wheel for my 36 plymouth.
The stock wheel is frozen onto the 1/2 '' shaft. I can remove the nut, but the
wheel will not budge despite several attempts with varouis pullers.
The 1/2'' shaft is threaded at the end for the nut. It is basically a 36'' length
of 1/2'' round pipe within a hollow tube that enters the steering box.
The section that enters the steering box has a worm gear attached. It is imposible to remove the shaft without disassembling the steering box.
My question is :
I know I have to cut the housing and shaft to remove the steering wheel,
but will I be able to adapt an aftermarket wheel to this 1/2'' round pipe?
Old 09-22-2011, 11:37 AM
35terraplane's Avatar
Steering shaft
My question is :
Have you tried hitting the puller with a hammer when it is tight, also put some thing that will loosen the rust a little. You might have to give it a good hit. I would not suggest cutting the shaft unless you have another one.
Bob
Old 09-22-2011, 04:56 PM
Last journal entry: A few ongoing projects
Rather than cut the column and shaft, just cut the steering wheel off. You should be able to cut thru the plastic you will probably want to cut a few big chunks out then carefully cut thru the splined collar until your down to the shaft. An air or electric cut off wheel should easily do the trick.
48 plymouth steering TWOPLYM Suspension - Brakes - Steering 4 01-13-2007 01:18 PM
Steering Shaft Question Quarter Flash Suspension - Brakes - Steering 3 09-19-2006 01:36 PM
Steering shaft seal 1939d2/s10 Suspension - Brakes - Steering 3 08-12-2006 08:25 PM
Steering shaft chiss Suspension - Brakes - Steering 12 01-17-2006 04:03 PM
40 plymouth steering pmiller666 Suspension - Brakes - Steering 1 01-13-2006 06:26 AM
