36 Truck rear differential suggestions - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2009, 02:56 PM
iceman36's Avatar
Christmas gift request
Iím working on my wife to get a new rear end for Christmas. Ok guys calm down itís for my 36 Truck!
Doing rough measurements on paper, of a selection of wheel back spacingís and body width Iím ending up needing a rear end around 66Ē from wheel mounting surfaces on axel shafts.
To keep things consistent I would like to use something from GM possibly 1988 and up and 6 lug but not floating.
I have charts showing GM made OEM non floating 6 Logs rear ends but canít find actual measurements to know what is even out there to work with.
To save money a junkyard find that I could refurbish and upgrade later would work. I could redesign but would like to keep extra body work down if I can.
So does anyone have information or know of a web site with GM rear end widths info?
Happy thanksgiving to all
And have a Christmas you will never forget Öand a new yearís party you find hard to remember.
Mike
Old 11-27-2009, 04:06 PM
big gear head's Avatar
High Performance Rear Ends
The '99 and later GM truck rear ends are about the widest that I know of. The 4X4 rear ends are a little wider than the 2wd rear ends and have 6 lug axles. These are 8.6 rear ends and have 30 spline axles and use the larger 12 bolt differential bearings. Most of them have 3.42 or 3.73 gears already in them.
'36 Chevy truck wide 'glass fender Q BigunALE Body - Exterior 2 05-17-2007 06:57 AM
12 Bolt car and truck rear ends the same? zachscc Transmission - Rearend 2 01-18-2003 08:29 AM
Rear end swap for '53 Chevy truck Bruce H Transmission - Rearend 4 12-01-2002 12:43 PM
rear end for my 36 chevy truck leroux Transmission - Rearend 0 06-13-2002 08:44 AM
transmission rear end for 65 chevy truck shortwide65 Transmission - Rearend 0 05-28-2002 09:37 AM
