360 Mopar stumble... - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2007, 09:11 PM
BigBlockBanjo's Avatar
Hey guys,
I have a 360 in a '87 Dodge 150 4X4.
It was running fine when I got it, but it had a slight miss. The carb had started leaking gas So I got a rebuild kit, and did the job.(It's a Quadrajet)
Still missing, so I got some Autolite plugs, and wires. It starts right up and idles like a champ. But when you gas on it, it falls all over itself for about two seconds. It's worse when you load the engine up.
Any ideas??? It acts rich..so I put a 1/8" shim between the Acc. pump, and arm. It helped some, but I know that's just hiding the real problem.
I'm stumped! Any help would be appreciated.
BBBanjo
Old 04-20-2007, 12:08 AM
Anyone? I figured alot of people would have a 360 in their ride.....
Old 04-20-2007, 12:12 PM
Sir Joab's Avatar
MOPAR Guy
Last journal entry: Restoration of my Chrysler
Have you made sure your spark timing is correct? It might be too far advanced.
Mopar 360 Motor Question........ STATUTORY GRAPE Engine 5 09-07-2006 06:00 AM
How do I identify a 318, 340, 360 Mopar?? STATUTORY GRAPE Engine 4 04-19-2006 09:15 PM
Mopar 360 Motor Question........ STATUTORY GRAPE Engine 2 04-14-2006 10:10 PM
360 mopar crate engine 4t8merc Engine 0 01-21-2006 10:56 PM
mopar magnum stumble rally4x4racer Engine 3 02-08-2004 06:20 PM
