366 tall block - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-07-2003, 11:14 AM
Post 366 tall block
well i know that it is a big block and came out of a big truck. what if any performance mods can be made. what is the bore and stroke. casting # is 364779 any help would be great
thanks
denny
Old 02-07-2003, 11:21 AM
Post
Hey regal, sorry to break the news to you but i read a tech article in hot rod a while back about these 366 big blocks and my advice to you is to get a huge chain and use it for a boat anchor. Even old optimistic hotrod said that there wasnt much to get out of the motor. If i find the column ill tell you.
Old 02-07-2003, 11:23 AM
SAE Member; ASE Master Cert
Post
The engine is pretty much of a dog, you would be better off with a 454, if you want a big block. A bone stock 454 will run circles around a modified 366, plus you would have a real tough time finding any pistons for the 366.
Old 02-07-2003, 11:24 AM
Post
thanks for letting me im on my way to ace hardware right now
denny
Old 02-07-2003, 01:54 PM
ssaza's Avatar
Post
They are correct that it would make a good boat anchor,But save the Steel crank,Rods and main caps.everything else is junk,the crank is steel,will fit 396 and 427 Big blocks,the rods will fit the 396/427 motors,they are a little bit heavier than the stock 396/427 std. rods,and you could convert a 2 bolt 396/427/454 big block to a 4 bolt main if you had to.You are better off with a 454/427/396.Good Luck!
