37-48 ford spindles disc part number help - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-21-2011, 01:06 PM
Last journal entry: Getting there....I think
i just bought a set of 37-48 ford spindles, and want to know the bearings part number, seal #, 4 1/2 bolt pattern rotor, etc that i can purchase at local parts store. Thanks guys!
Old 12-21-2011, 03:53 PM
BOBCRMAN@aol.com's Avatar
Unless the local store is Speedway Motors. Nowhere..
Those old spindle axle pins are too long for regular modern hubs.. They must be shortened on a lathe. Re tapered and re-threaded. Then the cotter hole drilled..
While having this done, cut for Ford Granada, Volare(4 1/2") or Chevy Malibu (4 3/4") bearing sizes.
Old 12-22-2011, 09:42 AM
the spindles i bought are from speedway
Old 12-26-2011, 06:18 PM
47chevy's Avatar
Last journal entry: Here is the car after paint
I have just bought the kit from speedway. There is a machined adapter for the inner bearing. This lets the hub mount without having to machine the spindle. The instructions and part #'s are on speedways web site.
http://www.speedwaymotors.com/Brake-...-B-P,4575.html
Old 12-27-2011, 12:46 AM
so if i buy that i can purchase the rest at autozone?
Old 12-27-2011, 07:16 AM
47chevy's Avatar
You can buy the disc brake adapter kit and get the hubs and bearing locally. Probably cheaper to get everything from Speedway.
What does this part number go to? sarge884 Body - Exterior 3 11-18-2010 10:27 AM
Looking for part number for 69 z28 cam mouseman Engine 15 08-13-2010 07:21 PM
Part number help Brimstone General Rodding Tech 2 10-30-2007 09:40 AM
spindles on ford disc brake swap for 62 t-bird wildnickels Suspension - Brakes - Steering 3 03-20-2006 04:47 AM
Need help with part number mitmaks Engine 3 01-17-2004 10:41 PM
