37 Cadillac Windshield - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2005, 04:16 PM
Last journal entry: Buick
Alright, I have the new glass and the new rubber. Now the problem; the windshield has a chrome strip around the opening lip, therefore the window is held in place from the inside by the trim ring alone. The rubber does not have a lip which goes over the medal lip to seal out the weather. So, is the rubber pressed up against the medal by the trim ring enough to keep out the weather, or should I put something, like glue, in there to seal it.
Thanks Rick
Old 04-06-2005, 06:15 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
pic?
can you show me a picture?
thanks
sr66
"SlowRide66"
"Illegitimis non carborundum"
Old 04-06-2005, 09:28 PM
I don't know how to post pictures here so I put a couple in my project journal. In the pictures you can see the chrome trim ring which goes around the window opening and covers the pinch weld. From the inside you can see where the window, wrapped in rubber, butts up the the trim piece, and is then held in place by the interior trim molding. The instructions say to put a bead of sealant on the interior then the window (wrapped in rubber) and finally the trim molding. What I don't know, is what kind of sealant to use.
Thanks Rick
Old 04-07-2005, 07:55 PM
Rob Keller's Avatar
Wiki Edits: 38
im not real sure what kind of sealant to use best bet would be to call the place where you got the instructions
the glass is in rubber that goes from the inside?
i would think clear silicone would work the outside crime is just ornamental ... the inside molding is the one holding the glass ... right?can you post a pic of the glass w/ the gasket and 1 w/ the gasket alone in you journal
don't feel bad i cant post pics either
something to do w/size and bla bla yadda yadda im still trying to down size my pixelsor something idunno puters baffle me reading up on them i need a new pc but the one i want to have built is about $1200. ouch
ill check back w/ you tomorrow
sr66
"SlowRide66"
Old 04-07-2005, 10:46 PM
curly5759's Avatar
Working on a 41 cad series 61 as a street rod. Recently removed the windsheild, chrome and mouldings like you did. I plan on using weatherstrip cement or possibly clear silicone on the install. I'm not to worried about rust, I live in a dry climate. Your project journal looks great!
Old 04-08-2005, 11:25 AM
Weatherstrip adhesive sounds like it might work. I was kind of thinking of using it. Has anyone else used it for this application before?
Rob, it will be a while before I can get the pictures of the window and rubber posted.
Old 04-08-2005, 04:05 PM
Rob Keller's Avatar
Wiki Edits: 38
ok sounds good clear silicone cures all almost
curly & rick when you sat weatherstrip adhesive you mean like 3M yellow or black stuff (what i call GORILLA SNOT) ?
spell @u later
sr66
"SlowRide66"
Old 04-08-2005, 08:43 PM
curly5759's Avatar
Yes, i was thinking of the yellow stuff. (I call it gorilla snot also.) Problem with that stuff is it is so messy. I have yet to use it w/o getting strings of yellow coming off in at least one area. Plus, the yellow probably will show, so I dont think that's a good choice. Did not know it came in black. my vote= clear silicone as first choice, black GS as second. Good luck
Old 04-10-2005, 06:48 PM
Rob Keller's Avatar
Wiki Edits: 38
i do beleive it comes clear too but i think i dident have good results w/ it go with the clear silly cone that comes in the small tubes like the blue, red ,black but i would use the house hold stuff easy to clean up after its flashed (semi cured) let me know how u make out
sr66
"SlowRide66"
Old 05-20-2005, 06:45 PM
THE GLASSMAN
Shield Seal
Use 3M bedding and sealing compound,it can be purchased localy and will not promote corrosion like silicone will.
it is also dry rag clean up and won't harm the chrome or painted finish.
Old 05-20-2005, 07:35 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
thank you, i was going to say that. because for the past 30yrs+ i have been told that ..joe
Old 05-20-2005, 08:12 PM
grouch's Avatar
Last wiki edit: How to document your project
Last journal entry: 1949 Olds -- Rotisserie, pt. 9
Wiki Edits: 2
sr66
I'm off-topic here, but you can use 'mogrify' to resize images. It's a part of Image Magick ( http://imagemagick.org ), which is free. You could also use Gimp ( http://www.gimp.org ), which is also free. Gimp uses a toolset very similar to Photoshop, in case you're used to that. Image Magick and Gimp work on all major operating systems.
37 Cadillac Headlights RickB1B Body - Exterior 4 02-08-2005 05:56 PM
frames 37 chevy going on a 38 olds 38 old coupe Suspension - Brakes - Steering 0 05-24-2004 01:45 PM
Removing windshield? 87442lover Body - Exterior 5 04-01-2004 11:03 AM
Windshield Installation Stude Dude Body - Exterior 0 03-05-2004 08:28 PM
Windshield seal installation, 37 Ford Coupe Ted's37 Body - Exterior 3 08-14-2003 08:51 PM
