Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 37 Chev with Mustang II Alignment Question
  #33 (permalink)
Old 12-01-2012, 05:27 PM
NEW INTERIORS NEW INTERIORS is offline
life is a temporary assignment
Randy, I didn't say to use those, I said they were the same basic design and wonder why they don't make one for the Mustang II, what exactly do you mean?
Same basic design !!!! Don't look like it to me.. If you start pushing the bottom arm forward or backwards they will start to bind.. What he needs to do is check to see first, Is make sure these are inline WITH the crossmember.. I'm not saying this is his problem.. But it's the first thing I would check to be sure one of the arms is not out of line.. (Because someone might have welded one of the strut brackets more forward then the other..)
Just think about this.. These arms was made to stick straite out the side off this crossmember.. The strut rod was added to THIS set up to hold THAT arm in place..(because it wasn't a true a-arm) Why would you want one of you lowwer ball joints ahead of the other.. Or behind the other.. This Make no sense at all.. And as far as the new cars go.. I would be willing to bet.. there isn't one with the ball joints pass the other.. The top is one thing.. But I really believe the bottoms are in line..
