Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 37 Chev with Mustang II Alignment Question
  #55 (permalink)
Old 12-04-2012, 08:02 PM
Unks37 Unks37 is offline
I really appreciate all the effort everyone has put into this situation. My ability to get time to work on it has been put on hold due to my wife just having surgery.
I was able to get the before and after print out of the readings. Camber before was 1.3 on left and -1.3 on right. Caster before was -1.1 on left and -5.3 on right. Toe was -0.17 on left and -0.04 on right. SAI was 9.1 on left and 12.2 on right. Included angle was 10.4 on left and 10.8 on right.
Front readings before were as follows. Cross Camber was 2.6, Cross Caster was 4.1, Cross SAI was -3.0.
Rear Readings before are - Camber -0.3 left and 0.1 right. Toe was 1.30 left and -.069 right.
Rear Readings before were Cross Camber -0.3, Total Toe 0.61 and Thrust Angle was 0.99.
I have had the car out and driven it and it really doesn't seem to have any 'bad habits'. It tracks straight and doesn't pull. Doesn't seem to oversteer when turning. The power steering may be masking effort.
The Actual Final Readings per the print out are as follows:
Camber 0.2 Left and 0.4 Right, Caster -3.2 Left and -3.5 right. Toe 0.02 Left and 0.05 Right. SAI 10.1 Left and 19.1 Right. Included Angle 10.2 Left and 19.5 Right.
Front Final Readings were Cross Camber -0.3, Cross Caster 0.2, Cross SAI -9.0, Total Toe 0.06.
Rear Final Readings were Camber -0.5 Left and 0.2 Right, Toe 0.34 Left and 0.26 Right.
Rear Cross Camber -0.7 Total Toe 0.60 and Trust Angle 0.04.
I still intend to pull the wheels and take measurements and more pictures. It may be awhile before I can get the time to do it.
Thanks again to all who have spent so much time on this. I will post more information as I get to it
Thanks again,
Unk
