Thread Tools Search this Thread share on Facebook
  #1
Old 05-12-2009, 12:40 PM
Mikey37 Mikey37 is offline
37 chevy 216/6cyl
Is there anything you can do to get more power out of a 37 chevy 6 or should I just upgrade?Will the car be worth less if I upgrade everything motor,rear end,front end ???
Register now (free) or login to remove ads
Old 05-12-2009, 01:58 PM
matt167 matt167 is offline
Wiki Edits: 31
not really much of anything you can do for it.. split the manifold, bump the compression but thats about it... upgrade to a 235, will look much the same, more power tho
Old 05-12-2009, 02:02 PM
h0trod389's Avatar
h0trod389 h0trod389 is offline
youll see me sideways
and if you get a late model 235, it has better oiling, instead of slapper spoons!
a 235 will render the same price as a 216..
Old 05-12-2009, 02:13 PM
richard stewart 3rd's Avatar
richard stewart 3rd richard stewart 3rd is offline
Last journal entry: 351W rebuild
Hi,
Yes you can get more power but not from that engine, an easy up grade is to swap the 216 for a 235 from a 55 to 63, it's basically the same engine w/more power & cubes & then you can visit in liners or 6=8 for more power options.
Rich
PS If you think the engine up grade will lower the value of the car, just keep the 216 & let it go with the car if you were to sell it. Ya know you can also change the trans, torque tube, & rear without a lot of problems, chevy love or s10 rear, synchronized trans., & again save the old stuff in-case you decide to sell
http://www.cliffordperformance.net/...egory_Code=C235
http://www.inliners.org/
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "37 chevy 216/6cyl"
ThreadThread StarterForumRepliesLast Post
37 chevy 2 door front endMikey37Suspension - Brakes - Steering104-27-2009 02:40 PM
37 chevy fenders vs. wheelsbodymanaceSite Suggestions and Help110-27-2006 10:29 AM
halogen lights in a 37 chevy p/ujunkyardjeffElectrical310-23-2006 09:51 PM
Frontclip for a 37 Chevy 1/2 Pickupjoerg-kaliSuspension - Brakes - Steering408-01-2006 07:46 AM
frames 37 chevy going on a 38 olds38 old coupeSuspension - Brakes - Steering005-24-2004 01:45 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
