37 chevy truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2010, 03:11 PM
37 chevy truck
just getting started on a 37 chevy pickup. I have spent an evening or 2 looking thru project journals for a similar project with no luck. Is there something out there I've missed? at this time I am especially interested in installing the windshield solid without hinges etc.
Old 11-19-2010, 10:57 PM
stea's Avatar
I did the framless windshield mount in my 39 gmc. The 39 has the 2 piece windshield but it should be the same mounting procedure. I had the glass cut from templates I made and used the primer and urathane to mount the 2 pieces like used in current vehicles. I also used the black primer about 2 inches all aroung the outside edges to hide the back of the dash and header panel. After the glass set I used a rubber moulding from the local windshield installer to fill the gap between the body and glass. Dont remember the actal part number of moulding though. Seems like the glass to body gap was about 1/4 inch. Used the urethane to set the moulding. I had to use masking tape in some area to hold the moulding flat untill the adhesive dried. Worked great, no leaks at all.
Old 11-22-2010, 05:13 PM
Stea thanks for your reply it was very helpfull. You have a great looking truck. I have reviewed your photo album it looks like you have done most of the things I still need to do. Do you have project journal.
Old 11-22-2010, 09:35 PM
stea's Avatar
Sorry I dont, didnt have a digital camera when I started. Just plain lazy in that department
Just send me a pm on anything you might want to ask and Ill help you the best I can.
Help! what frame to put under a chevy 1 1/2 ton truck? Riley Hotrodding Basics 10 02-15-2009 08:15 AM
s-10 front clip on a 50's chevy truck smokinbrinkman Suspension - Brakes - Steering 6 07-08-2008 11:48 AM
54' Chevy Truck paddlin4reds Introduce Yourself 3 11-28-2007 01:34 PM
94 chevy truck runnin' like poo! bluesmanjesse Engine 11 11-09-2006 02:54 PM
Car 235ci into '53 Chevy Truck New2theart Engine 8 10-17-2006 12:37 AM
