37 Dodge disk brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2011, 02:47 PM
Hi,
I have a 37 B coupe with stock front axle. I would like to convert the brakes to disk. I was wondering if someone on the BB has done this conversion and what parts were used?
Thanks in advance
Sam
Old 01-08-2011, 04:17 PM
Wiki Edits: 27
36 plymouth
My son has a 22 dodge lakester with a 36 plymouth wiggle tube axle. someone converted to camero disc's, but it wasn't done right. they used about a i inch spacer under the spindle nut and the caliper brackets did not have the torque stop designed in the pattern , when it stops all the stress is on the 2 caliper bolts.
Old 01-08-2011, 04:26 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Not to be quoted for sure but I seem to remember from a couple of years ago some guy using Dodge Coronent rotors and calipers and makeing some adapters.Not a lot of aftermarket on those..worth a try..
Sam
Old 01-08-2011, 09:07 PM
This is an easy conversion. Get the rotor, caliper, and bracket from a 2000 to 2005 Buick LeSabre with 15" rims. You use the stock hub and bearings. Turn the pilot on the hub down about .020 to fit snugly in the Buick rotor. File the lug holes on the Buick rotor to match the Plymouth bolt pattern, also about .020. Use 1/2" by 2" fine thread allen bolt for lug studs, installed from the inside of the hub. Install the hub on the spindle, install the caliper, and bracket over the rotor with new pads, and a piece of .020 cardstock between the inside pad and the rotor with the piston pushed all the way in. Make a .125" space between the caliper bridge and outside diameter of the rotor. Clamp it all in place. Make an adapter bracket to fit the bolt holes on the spindle, that the caliper bracket can bolt to. Spacers as necessary. That should do it. The rotor for 16" rims is bigger, and won't clear a lot of 15" rims, but if you are running bigger rims they will work.
disk brakes conversion no pressure to back brakes shiner Suspension - Brakes - Steering 10 01-24-2011 11:09 AM
Disk Brakes on 54 Dodge P/U abolton Suspension - Brakes - Steering 2 10-28-2009 06:16 AM
disk brakes bwhokie Suspension - Brakes - Steering 2 02-14-2007 10:53 PM
Disk brakes Les Forbes Suspension - Brakes - Steering 1 02-12-2005 03:01 PM
c-10 disk brakes Skokz13 Suspension - Brakes - Steering 1 05-28-2003 03:44 AM
