37 Dodge Rack & Pinion on Straight Axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2011, 06:21 AM
Hi,
I would like to install a power R & P on my 37 Dodge. The car has a Chevy SB with the original steeling box and setup. I would like to keep the straight axle. I'm a newbie at this kind of thing and would like to hear from someone who has installed one, I have been told that there are two ways of to go about it. Either axle mount or frame mount. Would the Dodge have different issues for installation compared to other cars ??
Also I would like to install disk brakes. All the sites I have visited talk about machining the spindles. Is there an aftermarket company making direct fit kits for the 37 ???
Any info would be greatly appreciated !!!
Sam
Old 02-12-2011, 04:47 PM
BOBCRMAN@aol.com's Avatar
I have done Must ll to a tube axle. The biggest problem with axle mounted systems is. There has to be a "slip" joint in the steering shaft. I just used a GM double"D" shaft. But had to service it a couple of times. Pre mature wear because the GM shaft is not made for constant length movement.
I have done a frame mounted GM Cobalt unit on a model "A" Ford. The unit must be parallel with the axle steering arms at ride height. To avoid excessive bump steer.
Old 02-12-2011, 05:27 PM
37ford4dr's Avatar
bobs77vet
Last journal entry: frame repair
if you need to read about go to the steeroids website ...i put this system on my vette i think its made by speed direct.
Rack and Pinion with a straight axle Chris Kemp Suspension - Brakes - Steering 7 01-10-2009 08:15 AM
split straight front axle with rack and pinion dmcurry22 Suspension - Brakes - Steering 15 01-08-2009 11:15 PM
Rack&Pinion on old type straight axle austin Suspension - Brakes - Steering 53 01-29-2007 08:18 AM
Custom Classic Trucks Rack & Pinion/Straight Axle 49_chevy_truck Suspension - Brakes - Steering 1 02-04-2006 09:35 PM
Straight Axle and Rack & Pinion Murff Suspension - Brakes - Steering 12 06-15-2004 03:21 AM
