Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 37 Ford Pick Up interior ?
Old 04-13-2013, 07:32 PM
slodat slodat is online now
Last journal entry: Getting Started with Upholstery
I did a '34 Ford truck like this.. The corners are 3mm PVC foam board shaped to fit the cab. The center is a very close fit to the window garnish molding. They are riveted together, covered in 1/8" closed cell foam to level everything out. The roof is a flat piece covered in the same foam.
