-   -   '37 Ford pickup door window channel question (http://www.hotrodders.com/forum/37-ford-pickup-door-window-channel-question-212433.html)
AZDoug 01-13-2012 03:58 PM
1 Attachment(s)
Which end goes up? The flared end with the slot, or the end with the tab inside?
Thanks,
Doug
rustman 01-29-2012 09:41 PM
window channel
I believe the flared end goes up. The tab on the other end holds the bottom of your vertical window felt in place. I will check it tomorrow and if I am wrong I will let you know.
AZDoug 01-29-2012 10:01 PM
I figured it out, the flare does go up.
The instructions with the new Bob Drake channel liner I just got helped.
Thanks,
Doug
