Thread Tools Search this Thread share on Facebook
  #1
Old 01-13-2012, 03:58 PM
AZDoug's Avatar
AZDoug AZDoug is offline
'37 Ford pickup door window channel question
Which end goes up? The flared end with the slot, or the end with the tab inside?
Thanks,
Doug
Register now (free) or login to remove ads
Old 01-29-2012, 09:41 PM
rustman rustman is offline
window channel
I believe the flared end goes up. The tab on the other end holds the bottom of your vertical window felt in place. I will check it tomorrow and if I am wrong I will let you know.
Old 01-29-2012, 10:01 PM
AZDoug's Avatar
I figured it out, the flare does go up.
The instructions with the new Bob Drake channel liner I just got helped.
Thanks,
Doug
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "'37 Ford pickup door window channel question"
ThreadThread StarterForumRepliesLast Post
54' chevy 4 door window channelgavinpierceInterior301-11-2011 07:27 AM
How do I remove left power window mtr in '97 Chev pickup door?piniongearGeneral Rodding Tech608-01-2008 11:15 PM
Where can I get the U-channel metal to make door window frames? Pic..F&JBody - Exterior707-10-2007 06:41 PM
Sealing front and rear window channel questionflipp121Body - Exterior502-20-2006 10:14 PM
driver window 40 ford pickupsonyInterior101-07-2003 08:38 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
