Thread Tools Search this Thread share on Facebook
  #1
Old 12-30-2011, 01:36 PM
AZDoug's Avatar
AZDoug AZDoug is offline
'37 Ford pickup hood center hinge question
The original top cenetr hinge allows the hood top panels to completely fold over on to each other, they also allow the hood pieces to slide apart.
I have a stainless replacement hinge from Bob Drake in hand, and the new hinge is locked together, you can't slide it apart, it also only open about 90 degrees, not 180 degrees like the original.
Was the original hinge locked together with limited opening angle,a nd it is now just worn out? or is the stainless replacement hinge funky, or perhaps modified so the hood panels can't become misaligned?
It there an advantage to one over the other?, other than rust resistance of the stainless hinge.
Thanks,
Doug
Register now (free) or login to remove ads
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "'37 Ford pickup hood center hinge question"
ThreadThread StarterForumRepliesLast Post
hood hinge questiontcoopBody - Exterior3701-05-2010 10:01 AM
'36 Ford hood hinge repair questionflynbrian48Body - Exterior112-28-2007 04:22 PM
Best Hood hinge system 4 1934 FordBartHotrodding Basics512-11-2007 05:43 AM
32 Ford door hinge question w/picF&JBody - Exterior008-11-2007 09:47 AM
39 Plymouth center hood trim/hinge1939P7Introduce Yourself212-09-2004 08:30 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
