-   -   '37 Ford pickup is progressing. (http://www.hotrodders.com/forum/37-ford-pickup-progressing-187423.html)
AZDoug 11-10-2010 12:45 PM
5 Attachment(s)
Ordered TCI frame in April, it showed up July11,
Progress so far: (some out of order).
AZDoug 11-10-2010 12:48 PM
5 Attachment(s)
More pictures
AZDoug 11-10-2010 12:49 PM
4 Attachment(s)
Even more pictures
AZDoug 11-10-2010 12:51 PM
5 Attachment(s)
And yet more pics
AZDoug 11-10-2010 12:59 PM
4 Attachment(s)
More pictures
techinspector1 11-10-2010 03:06 PM
Doug, interesting project. One thing though, NEVER, EVER use concrete blocks or wood to chock up anything heavy. Jackstands engineered for the job are the only things that should be used. Believe me, I'm 68 and everything still works because fellows smarter than me helped me to learn not to use concrete blocks and wooden blocks under cars.
AZDoug 11-10-2010 04:18 PM
Thank you for your concern, but if you look very closely at the picture, you can see the cab is supported from the rafters, by cables and backup ropes, and the concrete blocks and jackstands are a safety.
That was deemed the safest way,as I don't trust only overhead support unless it is some industrial lift, and even then I don't trust it.
I used the winch system I use to R&R the bed shell on my pickup for lifting the cab, and moved blocks and jackstands under each time the cab went a little higher. Additional 1000 pound tensile ropes were used at highest elevation as a third failsafe to backup the cable lift.
No way i would have let that cab just sit on stacked blocks, one good sideways push and it could have gone over.
Doug
bigdog7373 11-10-2010 04:24 PM
That truck's awesome. What kind of engine? Just wondering, why didn't you use an old school engine instead of the usual chevy v8.
AZDoug 11-10-2010 04:47 PM
I had the 327 that came out of my Corvette sitting around with no other use for it.
As far as going old school, I assume you mean flathead ford, which would be really cool, but I want a nice driver streetrod, auto trans (200-4R), AC, PS, PB, etc.
Anymore a Chev SB IS old school, many auto parts stores have to special order in things like thermostat gaskets, and such.
Doug
techinspector1 11-10-2010 10:48 PM
Doug
Doug, I understand what you did and how you did it, that's not why I made the post. I wanted to make a statement early in this thread which says that concrete blocks and wooden blocks are not valid support devices. Youngsters looking here may see the photo without reading the accompanying text and think..."Hey, I saw 'em do it on the forum, it must be ok. I won't need that stuff that goes over the rafters."
I've read and heard too many horror stories about fellows who are crushed to death due to the failure of concrete blocks, then found by a family member.
AZDoug 11-11-2010 10:03 AM
That is why, even supported from the top, and the blocks as safety support, I always had another person around as watch when I was cleaning up and painting the bottom of the cab. I don't trust anything above me unless is is on welded or bolted steel framing.
Doug
AZDoug 01-08-2012 12:58 PM
2 Attachment(s)
Update.
I have left a lot of pictures in between last post and now out, but the truck is back from paint.
It still needed the wiring harness installed and a bunch of assembly to do.
Doug
1957plymouthhemi 01-08-2012 04:05 PM
It came ouit very nice....I like the color choice.
Riot Racing 01-09-2012 09:10 AM
Update.
Doug
How do you like that rear suspension? Are you running a panhard bar?
I have a 38 Ford truck that is sitting on a Chevy S10 chassis. I want to change the rear suspension. I was debating between a four link and a trailing arm type setup.
Is your rear suspension one of those universal kits? Where did you buy it from?
AZDoug 01-09-2012 09:54 AM
The rear was part of the TCI frame package, yes it has a panhard bar, haven't driven it more than up and down the driveway yet to comment.
Doug
