Doug, interesting project. One thing though, NEVER, EVER use concrete blocks or wood to chock up anything heavy. Jackstands engineered for the job are the only things that should be used. Believe me, I'm 68 and everything still works because fellows smarter than me helped me to learn not to use concrete blocks and wooden blocks under cars.
I had the 327 that came out of my Corvette sitting around with no other use for it. As far as going old school, I assume you mean flathead ford, which would be really cool, but I want a nice driver streetrod, auto trans (200-4R), AC, PS, PB, etc. Anymore a Chev SB IS old school, many auto parts stores have to special order in things like thermostat gaskets, and such. Doug |
I've read and heard too many horror stories about fellows who are crushed to death due to the failure of concrete blocks, then found by a family member. |
That is why, even supported from the top, and the blocks as safety support, I always had another person around as watch when I was cleaning up and painting the bottom of the cab. I don't trust anything above me unless is is on welded or bolted steel framing. Doug |
Update.
I have left a lot of pictures in between last post and now out, but the truck is back from paint. It still needed the wiring harness installed and a bunch of assembly to do. Doug |
It came ouit very nice....I like the color choice.
I have a 38 Ford truck that is sitting on a Chevy S10 chassis. I want to change the rear suspension. I was debating between a four link and a trailing arm type setup. Is your rear suspension one of those universal kits? Where did you buy it from? |
| USING LATE 80'S FRAME FOR A 1937 FORD PICKUP | DIGGER | Body - Exterior | 23 | 10-07-2009 07:43 AM |
| Making a 64 ford pickup 2wd into a 4wd??? | Rod stalker | Transmission - Rearend | 0 | 01-06-2009 07:06 PM |
| 36 Ford Pickup truck radiator/grill shell assembly | Wes Searcy | Introduce Yourself | 11 | 10-03-2008 03:08 PM |
| 37 ford pickup | 66 chevy | Hotrodding Basics | 4 | 09-13-2005 04:50 PM |
| catalog for a 37' Ford Pickup ? | 34_26_36curves | Interior | 5 | 09-07-2005 11:59 AM |
