37 Ford Pulling Steering Wheel
Ok - I know this has to e easier then I am making it.
I am trying to pull the steering wheeel and steering column out of my 37 Coupe - I have removed the 1 inch nut on the wheel the 2 bolts that hold the colun to the dash and the bolt that holds the clamp around the steering box - but it still seems to be held in place - How does the steering wheel get removed from the column, then how Do I remove the cloumn? Thanks Clark |
Use a tool called a steering wheel puller to remove the steering wheel. To remove the column ...you have to disconnect the steering shaft where the coulmn shaft connects to the shaft going to the steering sector. ...it will either be under the floorboard or on the other side of the lower part of the firewall. It will probably disconnect at a u-joint. Is this the original 37 column or a more modern one that somebody has installed?
This is an original 37 set up - THe steering wheel does not Have the 2 or 3 bolt holes to use the steering wheel puller - I will need to form a bracket to go behind the wheel to pull There does not appear to be a universal - Just a cover that goes over the steering shaft right down to the steering box - It appears to be 1 piece right to the worm gear in the box Clark |
Clark |
sorry can't help you but i am doing a 37 4dr sedan....so keep us posted...what are you doing for the drive train? bob
I am planning this as a 5 year project - so I am sure things will change as it matures Clark |
i will be keeping a flat head also and adding the 5 spd tranny...i will be adding the 39 hydraulic brakes and keeping the old wheels....but will lower the front with a dropped front axle.....keep us posted how you are making out,its more fun when someone else is doing a similar project....., i am also working on the body issues and you see what i am doing over in the body/ exterior section i have a post called something like "getting serious on the 37" check it out well getting ready to get serious on the 37 |
Your Floors and quarters look like mine - Good Luck with the project Clark |
Clark are you located in eastern PA? bob
Location
Yes Bob - I am in Norristown - Near Valley Forge Park. And You? Clark |
You can use your 37 drums if you are converting to hydraulics. All you need are a set of 39-41 backing plates. New cylinders, springs, hoses, and relined shoes and you are stopping. New drums should be available from Joblot Automotive in Quenns LI NY.
Frisco's recommendation is the standard method for pulling the wheels on the old rigs with solid steering shafts. The key is the pressure against the back side of the wheel with your knees and the quick square rap with the hammer.
NOTE!!! you do not want to use this method on late model steering columns as you will collapse the column most of the time. A wheel puller has to be used for these. |
| 37 Ford Sedan Slantback Fan | GeneK37 | Introduce Yourself | 3 | 12-02-2006 04:40 PM |
| Need steering help with my '37 Dodge coupe! | el-cid | Suspension - Brakes - Steering | 10 | 09-07-2005 10:19 PM |
| steering wheel adapter | imgr8 | Introduce Yourself | 2 | 11-20-2004 03:20 AM |
| Steering Wheel replacement | tbag231 | Introduce Yourself | 1 | 10-10-2004 10:56 PM |
| 40 Ford Dash in a 37 Ford?? | Carnut39 | Interior | 1 | 12-05-2001 05:51 PM |
