37 ford rad-chev 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2011, 01:55 PM
Hi there will a 37 ford rad cool a stock chev 350 with the appropriate hose tubes blocked
thanks
Old 01-15-2011, 04:42 PM
37jim
If what you mean is a flathead rad I doubt it would work very good I have a 37 ford with a351 w in it and I had the local rad shop put a 4 core rad in and I used the top tank ' I believe the flathead rad is separated into 2 parts one for each side of the engine . If you do take that old rad in make sure you get the old rad parts back as they are brass and copper and worth good money as scrap
Old 01-15-2011, 05:28 PM
Yes it is a flathead rad. I guess i will get a custom one made up
thanks
Old 01-16-2011, 07:16 AM
345 desoto's Avatar
Location: Skaneateles, NY Summer/Port St.Lucie, FL Winter
The radiator in this car is a Stock 32 Ford 4 cylinder radiator. I had the bottom tank turned around, and the outlet reinstalled to route to a Chevy style waterpump. Cools beautifully, with no hint of overheating...
Ford P/U seats in a Chev P/U weedy64 Interior 1 02-13-2010 10:26 AM
56 chev rear end out 9 ford in retired 56 Transmission - Rearend 6 01-29-2007 07:10 AM
Ford Chev WHAT? 53fordguy Hotrodders' Lounge 22 04-13-2004 06:59 PM
why the big dogs like chev or ford? PropanePower Hotrodding Basics 10 02-21-2004 12:55 AM
ford 9 inch or chev 8.5 what should i do tyson Transmission - Rearend 4 08-01-2003 12:11 AM
