37 ford rear window install - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2009, 09:57 PM
Im trying to install the rear window regulator . The window wont line up properly once its lowered and raised. Am I missing something I bought a window kit from Vintique. It came with all the dampers .
Old 03-27-2009, 06:56 AM
DanTwoLakes's Avatar
Wiki Edits: 22
I'm going to move your question to General Rodding Tech. I think you will get better answers there.
Dan
Old 03-29-2009, 12:12 AM
dinger's Avatar
Did you get all the gear needed? I just took mine out of my 36, I am not going to use it. It's pretty complex looking, 2 large gears meshing to lower and raise the window.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 03-29-2009, 02:25 AM
Ifit aint fix...Don't broke it
Last journal entry: I am ALIVE! 65GTO FRAME OFF
ummm check the part
I had the same problem and i finally figured out that the kit was for a earlier year and put in the wrong box. It was from the same company. The window angled too much when it came all the way down and then curved too much at the top. It turned out ok they shipped me the right parts. Just a pain. I was working on a 40 and had a kit for a 37-38. Also check if your right left is correct. I have been a real duffuss complaining only to find out I am putting the right on the left..... If you only using one make sure they shipped you the proper side.
Old 04-06-2009, 01:46 AM
Thanks guys Ill check both those things . The winder came with the car so it may not be the correct one.
Old 04-06-2009, 08:21 AM
dinger's Avatar
Take a pic if you can, I'm not using the reg. from mine.
Ford 8" rear end Mel Smith Transmission - Rearend 6 09-10-2007 11:31 PM
8.8 Ford rear end in my 79 G body Malibu 79 Malibu327 Transmission - Rearend 4 05-20-2007 02:26 PM
Ford Rear Discs, revisited. DONE! Psquare75 Suspension - Brakes - Steering 39 07-18-2006 06:10 PM
53 ford f100 rear window tgregoire Body - Exterior 1 07-16-2002 06:20 PM
40 Ford Tudor rear window regulators Tooch Body - Exterior 1 03-12-2002 10:30 AM
