37 Ford Trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2010, 12:54 PM
37 Ford Trans
Just wondering if there is any adapters out there for hooking say a modern 4 cyl or small v6 to a 1937 ford driveline. (Trans and torque tube rear end). Going for a cheap rat rod cruiser build.
Old 04-02-2010, 07:20 PM
Try advance adapters.
Old 04-02-2010, 07:29 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you want to use a Chevy V6, V8 or inline 6 engines, use something like THIS.
Another way of going about this (added expense but added strength/durability/drivability) is to convert to an open d-shaft and use a manual from the same donor vehicle as the engine comes from. The old three speed floor shifted trannys are not exactly the epitome of durability and IIRC lack syncro low.
Old 04-02-2010, 07:39 PM
Wiki Edits: 27
rat build
I would go for the 5 speed to match the engine. S 10 5 speeds have the stick farther foreward. I have reworked a Mustang II 4 speed to move the stick foreward. Some Aerostar trans have the castings for different stick locations. going to an open drivelind would require more beef than the rear wishbones. the torque tube is the strong part that transmit the driving force to the chassis
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 07:31 PM
37 ford conversion to later ford hydraulics 37ford4dr Suspension - Brakes - Steering 4 11-29-2006 07:46 PM
Ford y block 4 speed trans RetroJim Transmission - Rearend 3 05-26-2006 05:59 PM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 06:29 AM
40 Ford Dash in a 37 Ford?? Carnut39 Interior 1 12-05-2001 06:51 PM
