37 Ford Wild Rod electrical question - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-17-2011, 05:23 PM
EOD Guy's Avatar
Changing the batt from the red top to a normal batt should not have made a wire fry..... did you hook it up correctly?
  #17 (permalink)
Old 02-21-2011, 01:34 PM
I have seen the hot wire from the battery get hot if the motor is not grounded. A wire from the bell housing to a clean spot on the frame will cure that . Did you have the book that the car is supposed be wired from? I have not tryed to check one with the motor not grounded so can't say if that will make the light stay on or not may be some one else can speak to that. I do know a short is/can be a PITA GOOD LUCK.
OLDROD
PS The book would help you know where to start looking.
  #18 (permalink)
Old 02-21-2011, 03:36 PM
EOD Guy's Avatar
If not already done so.... I'd hook the neg cable from the neg post on the batt directly to the block.
If he had a red top Optima hi preformance batt in it previously and simply replaced it with a normal battery and hooked it up the exact same way it came out, there should not be an issue with a wire frying....... or it would have done it before with the old battery.
Electrical diagram ford f-150 99 ardibel Electrical 1 08-07-2010 06:58 PM
Electrical Question Willie496 Electrical 9 09-03-2007 03:02 PM
Ford Electrical Problem BigJoeGrit Electrical 6 01-18-2007 06:41 AM
question about electrical Thuggishruggish3000 Electrical 2 01-16-2004 02:06 PM
Electrical question solgood71blazer Electrical 0 01-11-2003 10:54 AM
