37 hudson terraplane coupe - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2006, 03:53 PM
dermott's Avatar
any one know how i can mount craegar s/s rims onto a stock terraplane front/rear axles ? these do not have studs in drums, but bolt on like a vw. i would like to keep 16x6 w/w tires radials. thanks.
Old 02-18-2006, 06:07 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
is there any way you can thread some studs through from the back of the drum and then use the studs to mount the rims? or is the bolt pattern even the same?
JB
"Well done is better than well said." - Benjamin Franklin (1706-1790)
37 terraplane coupe dermott General Rodding Tech 5 02-24-2006 06:59 AM
37 chev coupe 40 pontiac coupe duke mauk Introduce Yourself 2 01-25-2006 12:50 PM
Need steering help with my '37 Dodge coupe! el-cid Suspension - Brakes - Steering 10 09-07-2005 10:19 PM
37 chevy coupe frame nomadbb Suspension - Brakes - Steering 2 02-18-2005 04:32 PM
37 Ford Coupe Dimensions MARCELO URUGUAY Body - Exterior 4 12-14-2004 08:29 PM
