37 plymouth front drum brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2011, 12:17 AM
Hi
I have just aquired a 37 plymouth 4door sedan but it is missing the front brakes.I need everything. The stub axles are OK.
Old 07-24-2011, 10:01 PM
Wiki Edits: 27
disc swap
My son's 36 came with a wiggle tube axle and a disc brake conversion, that is now under the other son's 22 dodge lakester, the 36 is slated to get a mustang II swap. if you are going to rod it, look into disc's.
rear end disks brakes that bolt up in place of drum brakes that has a 383 465hp engin calon Introduce Yourself 2 01-23-2011 06:52 PM
Power boost drum brakes vs. disc brakes??? woodscavenger Hotrodding Basics 13 08-08-2007 02:07 PM
Front Disc Rear Drum Brakes bigjoedo Suspension - Brakes - Steering 2 07-02-2004 10:16 AM
Front drum "juice" brakes on a 32 Ford 32Steel Suspension - Brakes - Steering 9 03-03-2004 04:29 PM
front brake diagram drum brakes 72chevyelcamino Suspension - Brakes - Steering 0 10-28-2002 02:17 PM
