37 pontiac/nova sub - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-24-2007, 11:47 PM
Slantback's Avatar
37 pontiac/nova sub
I've got a 74 nova subframe for my 37, anybody done one of these? I'm looking for some pics or info on where to graft the two together. I've seen it done several ways. I'm thinking about 4 inches or so in front of the front body mount cutting the frame at about 45 degrees so that it will meet up with angle on the subframe. Any thoughts will be appreciated.
Thanks, Slantback
Old 11-25-2007, 05:52 AM
poncho62's Avatar
Wiki Edits: 5
I did a Nova sub on my 51 Ford F1.......I used the whole clip and positioned it under my existing frame............This was 15 years ago and it has held up well. See pic.
Seems to me. a Nova clip may be a bit wide for a 37. It is a tad wide for my truck, but did work.
ID:	25787   Click image for larger version
Ontario Rodders
Did Ford make a 3 Window 37 Coupe 37FordCoupe Body - Exterior 2 07-22-2007 08:26 AM
Fender Replacement for '37 P3 Plymouth Business Coupe hduff Body - Exterior 3 06-01-2007 01:38 AM
37 Ford trunk hinges APalusky Body - Exterior 3 12-17-2006 09:26 PM
37 willys gmwillys Body - Exterior 1 06-14-2005 02:51 PM
frames 37 chevy going on a 38 olds 38 old coupe Suspension - Brakes - Steering 0 05-24-2004 01:45 PM
