Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 373 1539
Thread: 373 1539
Old 06-01-2009, 12:16 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by NaythanOldskool
I pulled the valve covers and the numbers are the same and their both 3731539. The engine has a point distributorand also a blow off valve behind the ditributor. The engine block cast is the same as the head. The thing that gets me is that the suffix code. its T225D and that doesnt make any sense to me.
You most likely have a 283. I see no blocks w/the same cast number as the one for your heads, some are close- you might want to double check the block c/n.
HEADS
3731539....57......283..........283 HP
SUFFIX CODE "D"
D 56 265 Truck 205 HP RPO 410 w/Manual 4-Brl
D 58 283 Impala 185 HP Base Power glide 2-Brl
D 59 283 Impala 185 HP Base Power glide 2-Brl
D 60 283 Impala 170 HP Base Power glide 2-Brl Hyd Cam
D 61 283 Impala 170 HP Base Power glide 2-Brl Hyd Cam
D 62 283 Impala 170 HP Base Power glide 2-Brl Hyd Cam
D 63 283 Impala 195 HP Base Power glide 2-Brl Hyd Cam
D 64 283 Impala 195 HP Base Power glide 2-Brl Hyd Cam
the carburator on it is a holley but looks like a elderbrok or a carter.
There's a Rochester 4G from that era that looks a little like a Carter/Eddy, but I'm not familiar w/a Holley that looks like that.
