373 or 383???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2006, 10:27 PM
373 or 383????
i have 350-4 bolt main. When my father bought it, it was bored .40 over. About 8 months ago, we had the motor rebuilt because the inside of the cylinders were cut up. Since then, the motor has been bored over .60 over with a bigger cam. The guy who built the motor told me it was called a 373. But i have other people telling me its a 383. Does anyone know what the real numbers are?
Old 05-15-2006, 10:33 PM
GoneNova/406's Avatar
a 350 bored .030 over is a 355,a 350 .060 over is a 360,now add a 400 crank shaft and you have a 388 or for .030 over its a 383.
Old 05-15-2006, 10:39 PM
thanks, the only thing i dont know is what size crankshaft or cam he put in it.
Old 05-15-2006, 11:22 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Take the oil pan off and check the casting number on the crank, if it's a factory crank. I dont know how aftermarket cranks are labeled.
Ok, here's the debate of the century: 383 or 400 chevy!! Cast your vote and reason killerformula Engine 303 03-28-2013 09:08 PM
383 Stoker vs 383 Chrysler Jag Daddy Engine 100 08-14-2008 12:48 PM
Supercharging and fuel injecting a 383 Chevy Noesis Engine 11 09-21-2007 06:51 AM
383 0r 406??? Zubair Engine 60 10-14-2005 08:53 PM
What makes a 383 so much more expensive? Chevy21 Engine 12 09-30-2004 09:55 PM
