377 or 400?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2010, 02:53 PM
377 or 400??
i want to know if i should build a 377 or a 400 SBC which will last longer? because i have a 400 cast crank and a 350 forged crank its for racing so it will take some tourture thanks.
Old 08-02-2010, 03:26 PM
Should we assume you have a 400 block to put either of these into?
Bogie
Old 08-02-2010, 03:51 PM
yess it is.
Old 08-02-2010, 05:50 PM
DoubleVision's Avatar
If I had a 400 I`d build a 400. a 400 will eat a 372 or a 383.
By destroking the 400 to a 372, your making it into what we call a hotter 350. It will run and act like a good strong 350 but will have improved power in the upper RPM band due to the larger bore`s ability to breathe.
We`ve built them all, 350, 372, 383 and none of them even came close to hanging with the 400.
Use 5.7 or 6 inch rods in your 400 build and this will increase it`s life. The issue`s with stock 400s is the long stroke and short rod places a high load on the thrust side of the piston increasing wear. Using the longer 5.7 rod reduces it some, a 6 inch rod reduces it even more. You can learn more about rod ratios here:
http://victorylibrary.com/mopar/rod-tech-c.htm
Old 08-02-2010, 06:31 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Why do people post the same question twice?
Nevermind that I mistook 377 for 383. lol
Old 08-02-2010, 06:57 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
I feel for Jeremy. Poor fellow, he has started 6 different threads now, trying to find out what to do with the few parts and little money that he has to work with.
http://www.hotrodders.com/forum/sear...archid=3639141
Jeremy, buddy, you need to save some money before you start on this motor. Last I heard, you had only 500-600 dollars to spend. That won't even pay for a stock rebuild. Save some more dough and do some reading while you save up. Here's a good start....
http://www.amazon.com/How-Rebuild-Yo...0797020&sr=1-6
Old 08-03-2010, 08:55 AM
i have been saving accually and now i have about 3000 dollars to spend so can you direct me to which parts i should buy how i should make this motor come alive!? Thanks
Maybe this kit would work? http://www.speedomotive.com/ps-541-8...crank-kit.aspx i have intake and 64cc camel humps and a holley 650 double pumper. and my dad and uncle used to race so i have all the gaskets. and was thinking about using this cam http://www.jegs.com/i/Comp-Cams/249/...oductId=746628 or whatever you have in mind?
Old 08-03-2010, 09:04 AM
SSedan64's Avatar
400?
What plans for the engine? Strip, Street/Strip? Normally Aspirated, Boosted, Nitrous?
Old 08-03-2010, 09:14 AM
its for muddrags 250 yds long and strictly for that and occationally screwing around. Run off of turbo blue no blower nos ect..
Old 08-03-2010, 01:15 PM
Magnaflux, and maybe even sonic-check that 400 first. If you buy parts for the 400 and find out the block is un-usable...money wasted.
Old 08-04-2010, 08:54 AM
the block is all ready it bored out magnafluxed and ready to go
I picked up a 400 SBC and a M21 4 speed Mustangsaly Engine 22 03-05-2010 09:32 AM
383 vs 350 TheCiscoKid Engine 86 05-03-2008 03:10 PM
? on a 377 sbc 1sik72chev Engine 2 04-28-2008 02:16 PM
a budget 383 stroker build using a stock 400 GM Crank Mustangsaly Engine 8 10-15-2007 12:57 PM
400 327 crank limey Engine 8 09-24-2002 07:53 AM
