I will also agree..... well prepped/balanced GM production cranks and rods will live in high rpm condition. I run a 355 with a GM crank and rods and turn it 7200 every shift. I have run so many bottles of nitrous in this engine that I cant even count. 4 years so far with only minor freshening.
hi their
i have a 64 nova building twin turbo engine do i need 377 or 400 or 383 need help
377 vega street car
I've got a '72 vega with a basicly stock 350 that i used for mock up. It also has a full man. turbo 350 with a tci 241000 converter [advertised stall 3000-3400, not sure what it is in a light car aprox. 2800lbs.] and a narrowed 12 bolt with 4:56s. I'd like to use my edelbrock str-10 crossram on it, but not a must i just like the retro and wow factor. Any way i was originally thinking of doing a 383 or 406 but i'm afraid that the low end torque and steep gear the car will = no traction. Also with this set up [383 or 406] i don't think the 5500-6000 rpm range would work well with the 456s and i really don't want to change gears again. I would like to take the car to the track once in a while and i dont think it would run through the 1/4 under the 6000 rpm limit. I thought the 377s lower bottom end grunt would get the car moving before getting in it's power range and would have plenty of rpm to run down the track. What do you think/suggest? Thanks, Todd.
anyone home?
I would personally build a 406 with 6 inch rods, more bearing clearance and forged internals with the pistons having mm style rings total sealed to turn up the heat all the way around. most tq at the bottom and most hp at the top end with the right cam and heads like pro topline 235s or big afr heads around 650 lift and 262 @.050 with a 1.6 rocker.
Interesting thread.
I think that building an effective high RPM package is more technical and complicated than a high torque machine, but make no mistake, it works! Gobs of torque is kind of a one size fits all proposition, effective in most all applications. One thing that is rarley mentioned in these threads is the fact that gear reduction = torque!! In a high reving package everything needs to be done right and made to work together. ALL of the engine parts and its composition as well as the rest of the car.. The whole idea is based on the principle that the HP "rate of gain" grows as the RPM's escalate and so they need to operate in a higher band. Pro stock cars are an excellent example of this principle, the amount of technology that goes into one of those motors alone is staggering, to say nothing of the rest of the car. They are able to run at speeds that are almost unnatural for carbureted engines because of their unprecedented utilization of RPM's. Weight to HP ratio is also another very important factor with a high RPM street rod. |
377
that's probably a result of excessive tire spin... getting better times with less power usually means there's a problem somewhere in the suspension or tires. |
First post on engine forum.
Hey guys, since we are talking about 400's. I am building a 406 sbc with a Scat lightweight 3.75" stroke crank which requires a 6" rod to clear the pistons. Using World 235 series alum. roller heads with oversized valves, a 0.700+ lift cam, and JE high domes. Don't plan on running NOS right away. With these little bits of engine info, what RPM range do you think this mill can be pushed to?
406 cam info
Hi Lapersinger,
Thanks for the reply, we are still gathering parts for the 406 and picked up a roller cam from a friend. You mentioned the 7500 range. Here are some specs from the cam card. Comp Cam 12-000-9, 106 LS, 306 IN/310 EX @ .020, 273 IN/277 EX @ .050. What do you think this would do for the RPM range? JayRod78 |
I don't pretend to know alot about Cams, but I think that cam is going to only be good from 4500-8000 rpm. If you plan on doing anything but full throttle driving then you will want to go another way.
What kind of a block are you using, you are spending alot of money on internals, I would hope you would get an aftermarket block to hold it all together. |
Has anyone else actually run this motor? I have been thinking about it and would like to hear from more people with more experience with it. The car is a 68 firebird that is getting an M-21, and a 9-inch in the next month or so after I finish gathering parts.
My goal for the car is for it to run a solid 12 second quarter mile and more importantly all around fun to drive. I also want to use (with the exception of safety items) parts that were available in the seventies where possible, my Dad has a set of camel humps he is giving me, how would these be on this motor? This is not a DD and is only driven when I want to, and I am used the quirks of a modified vehicle. I am thinking a nice fast spinning small block would be well suited to this goal. So please let me know if I am in line here. Josh Quote:
| 383 stroker kit (Ebay) | Hazard | Engine | 8 | 05-24-2006 06:51 AM |
| Ford 532 stroker | Jared | Engine | 12 | 05-09-2005 07:11 PM |
| 377 stroker question? | HemmiGremmie | Engine | 19 | 07-18-2004 11:13 AM |
| 383 Stroker kit on Ebay any good? | sb72elcamino350 | Engine | 1 | 03-04-2004 08:02 PM |
| 377 stroker | L98vette1986 | Engine | 3 | 06-23-2003 07:59 AM |
