Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 377 stroker
Thread: 377 stroker
  #36 (permalink)
Old 11-24-2007, 05:22 PM
chrismac chrismac is offline
I would personally build a 406 with 6 inch rods, more bearing clearance and forged internals with the pistons having mm style rings total sealed to turn up the heat all the way around. most tq at the bottom and most hp at the top end with the right cam and heads like pro topline 235s or big afr heads around 650 lift and 262 @.050 with a 1.6 rocker.
