Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 377 stroker
Thread: 377 stroker
  #44 (permalink)
Old 06-06-2008, 02:52 PM
Double_v23's Avatar
Double_v23 Double_v23 is offline
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
Originally Posted by JayRod78
Hey guys, since we are talking about 400's. I am building a 406 sbc with a Scat lightweight 3.75" stroke crank which requires a 6" rod to clear the pistons. Using World 235 series alum. roller heads with oversized valves, a 0.700+ lift cam, and JE high domes. Don't plan on running NOS right away. With these little bits of engine info, what RPM range do you think this mill can be pushed to?
What kind of a block are you using, you are spending alot of money on internals, I would hope you would get an aftermarket block to hold it all together.
