37jim - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2011, 03:55 PM
37jim
I have an odd problem . My 351W is new rebuild 1700 miles last summer OIl started appearing in the rad early on and by the end of summer had about 1 quart in the rad.The engine was a junkyard core that I sent away and had tanked and checked. It has Edelbrock Performer Plus heads and air gap manifold. I took the front timing cover off and everything looks fine. It makes me wonder if the oil gallery is cracked somewhere Any one have any ideas. My buddies have been on numerous other sites and nobody seems to know.
Old 01-15-2011, 03:59 PM
LATECH's Avatar
Last journal entry: New Gas Tank
Sounds like a crack somewhere, oil gettin in from a pressurized feed to the cooling system. Are you sure it is oil and not atf? the trans cooler in the rad could be leaking .
Old 01-15-2011, 04:08 PM
37jim
No the tranny has an air cooler
Old 01-15-2011, 05:35 PM
LATECH's Avatar
You mean a seperate cooler from the radiator, like an aftermarket trans cooler?
Old 01-15-2011, 09:20 PM
37jim
yes remote from the radiator
