37yrs old Too Old to Learn About Cars - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-10-2010, 10:18 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
Originally Posted by cutterbond
Gasoline- manufactures recommend premium gas for some cars, unless you are rolling a Corvette or a Viper, ignore that recommendation.
Most factory compression rations do not warrant anything more then 87 octane.
High octane is for high compression engines, anything below 12to1 compression works fine on 87(cheap stuff)
No disrespect intended, but that is an awfully "blanket" statement, and not necessarily correct. Other factors, such as carbon buildup, non functioning EGR valves, or prior modifications, can cause octane requirements to increase. As a rule, your motor will tell you if it needs higher octane fuel, knocking or pinging, but if you're not listening for it when trying a new fuel, you could easily do expensive damage to your motor.
Brake Fluid has a DOT rating, just make sure your DOT rating is at, or above, the recommended rating for your car.
Do NOT mix DOT ratings, brakes are no place for a failed chemistry lesson,
Coolant, it's more expensive to buy premixed but I recommend it, to mix non premixed coolant a rule of thumb is 50/50 coolant and distilled water.
And there is RED coolant, and GREEN coolant, green is most common, but newer cars can have RED coolant to, so double check before adding.
Again, just a little to general. Long life coolant is a good idea, but don't mix it, and definitely stay away from the orange Dex-cool, (AKA Death-cool), you will find VERY few GM technicians using it their own vehicles,
Google is your friend, just type in your problem and there will be information about anything car related somewhere.
And you got this forum too, do a quick search before asking though, sometimes the question has already been asked and answered.
Not a bad suggestion, but beware that there are folks out there posting info that is incorrect, check your sources, and try to verify the accuracy of the info with a trusted source.
  #17 (permalink)
Old 01-10-2010, 11:54 PM
I know I was being over general, but I wanted to lay down a basic working foundation without getting him lost in a sea of details.
Your counter points are great added notes.
  #18 (permalink)
Old 01-11-2010, 12:15 PM
Last journal entry: Metal Cancer is Found
Signed Up for 1st Workshop
Hey All,
Thank you for all your encouraging words. I just signed up for my first workshop, Metalwork. Here is the school www.sunchasertools.com Its a 3 day workshop. Sat,Sun, and Monday. The guy running the school asked me to bring in panels, how cool is that? All I have is my fender skirts, that need some work, but who cares, I'll be learning something...
Thanks Again....
  #19 (permalink)
Old 01-11-2010, 10:57 PM
Cool, you should take a picture of the panel you are bringing in before and after.
street legal race cars/ yes or no? skull Hotrodders' Lounge 10 06-10-2014 12:10 AM
Scratch Built Cars...(Home Made Rods) NEW INTERIORS Hotrodders' Lounge 163 04-09-2014 11:12 AM
cash for clunkers RONNYinWAXHAW Hotrodders' Lounge 105 08-20-2009 05:58 PM
Slot Cars cobalt327 Hotrodders' Lounge 12 06-22-2009 03:21 PM
1/24 model cars FoxThunder 5.0 Hotrodders' Lounge 24 04-25-2004 09:41 PM
