Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 38 cad restoration/ chevy 350 eng.
Old 10-30-2010, 08:42 AM
dorrsulee dorrsulee is offline
dorrsulee
Last journal entry: 1938 cadillac frame off restore
Originally Posted by mud.man.rj
Sounds like acool car, gave a friend a hand quite a few times on his 53 Cad. He had a strange auto trans in it , can't remember much about it, but I don't believe it would even come close to fitting a small block. Any idea on what trans your going to run and the mounting, just wondering on the amount of work for the trans, engine sounds easy. Happy Hotrodding.
I am using the original 3 spd column shift trans. and original running gear. It took more work then I expected. I used a extra 38 cad bell housing to modify. had to cut some of it and drill new holes. made 1 bracket to utilize all mounting holes on the chevy block. Critical part was lining up the pilot bearing to the trans. The chevy bearing has the same ID as the 38 cad trans. Also the cad 5 hole bolt wheels are the same as the ford 150. A lot of work but fun fun
