Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 38 cad restoration/ chevy 350 eng.
Old 10-30-2010, 09:26 AM
eloc431962's Avatar
eloc431962 eloc431962 is offline
Evil Wicked Mean And Nasty
Wiki Edits: 37
Originally Posted by dorrsulee
I am using the original 3 spd column shift trans. and original running gear. It took more work then I expected. I used a extra 38 cad bell housing to modify. had to cut some of it and drill new holes. made 1 bracket to utilize all mounting holes on the chevy block. Critical part was lining up the pilot bearing to the trans. The chevy bearing has the same ID as the 38 cad trans. Also the cad 5 hole bolt wheels are the same as the ford 150. A lot of work but fun fun
Sounds like you got it going on. Got any pics for us ?
