38 caddy door handles - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2008, 10:24 AM
41 kustom's Avatar
I need to know how to remove the inside door handles. I can't find any pin or spring when I move the escution. what would be the proper way without damageing the handle?
This is a 38 Caddy, Model 65, 4 door, touring sedan.
Old 02-12-2008, 08:05 PM
Always look up in a custom
My inclination would be to look for a roll pin holding the handle on. It may be further back than you think and still can't see even moving the plate. I redid a 1938 Plymouth interior that had handles attached with roll pins. Also most of the older jags I used to work on were held on that way.
500 Caddy rhanshaw Engine 23 08-07-2007 02:53 PM
Caddy Brake Fun & Does Line Size Matter? Help Needed. bigfred1958 Suspension - Brakes - Steering 5 04-06-2006 08:20 AM
Sealed Beam headlights for 38 Chevy Coupe? beeb Body - Exterior 6 05-15-2005 07:06 PM
frames 37 chevy going on a 38 olds 38 old coupe Suspension - Brakes - Steering 0 05-24-2004 01:45 PM
500 Caddy in a Monte. HemmiGremmie Hotrodders' Lounge 7 12-04-2002 02:53 PM
