38 chev door allignment - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2009, 11:35 AM
Last journal entry: dash mods
38 chev,exactly how do I shim body?
I have a 38 2 dr sedan. I'm starting my body work, car is assembled and running. The front fenders, hood and doors are all out of alignment.
I'm starting with the door allignment and read that they need shimming, but I can't find any references to WHAT size body shims to use and exactly what I need to do. Do I need to undo all the body bolts? The drivers door has sagged 1/4'' at the belt line and a little tight along the A pillar, gap under the A is good, the B pillar side gap is good..The passenger door is sagged 1/4'' but the B pillar door gap is wider at the top.The passenger side upper hinge broke and was welded,I think this caused the gap dif.
Old 10-17-2009, 07:01 PM
I have a 39 four door sedan. If you need any pictures let me know and I will see what I can do to help you out. I did not do the body myself but it lines up perfect. The front fender are from a 40 as I liked the lights better.
Name:	STREET ROD 010-2.jpg
ID:	41330   Click image for larger version
Name:	STREET ROD 2-1.jpg
need spring rates for 38 Chev kits TheCiscoKid Suspension - Brakes - Steering 9 09-10-2008 08:06 PM
looking for 38 chev fenders TheCiscoKid Body - Exterior 1 06-28-2008 06:51 AM
38 chev wiper tower parts? TheCiscoKid General Rodding Tech 3 05-02-2008 10:53 AM
38 Chev sedan triker Hotrodding Basics 13 11-17-2006 08:48 PM
Removing a Must. II crossmember for a 38 chev. frame ylchild Suspension - Brakes - Steering 6 01-15-2006 07:21 AM
