Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - '38 chev rear axle replacement
  #18 (permalink)
Old 10-20-2012, 07:14 AM
Too Many Projects's Avatar
Too Many Projects Too Many Projects is offline
A few beater muscle cars
Last journal entry: continued
Originally Posted by big gear head View Post
It's going to depend on how wide you want it. The X body rear ends are 60 inches wide and the 2nd gen F body rear ends are 61 inches wide. (....If you don't need strength you could use a G body 7.5 rear end that is 58 inches wide.....)
That chart has been around for a long time and is in serious need of some corrections. The '67 to '69 Camaro, '64 to '67 Chevelle and '68 to '79 Nova rear ends are all exactly the same width at 60 inches. The chart has them all different. Also the '68 to '72 Chevelle and '70 to '81 Camaro rear ends are 61 inches wide, not 62 1/2 like the chart says.
Todd, I am getting a '38 with an '80 Malibu 7.5 axle already in it. Is there any way to increase the strength of the components and add a posi ? It may be easier to modify it than hunt down an 8.5 Nova axle.
Thanks !!
