-   -   '38 chev rear axle replacement (http://www.hotrodders.com/forum/38-chev-rear-axle-replacement-224456.html)
Too Many Projects 09-28-2012 07:00 AM
I just bought a '38 Chev in original condition and will be replacing the drive train. I've seen different rear axles in these cars and am wondering which fits the frame the best. I am leaning towards a 8.5 10 bolt GM over a Ford. I see many from an X or F body car but need to know about the S10 series fit too. Any advise from the seasoned builders/owners will be appreciated....:)
RWENUTS 09-28-2012 07:40 AM
A chart for you. JFYI s10's come in 58 and 62 inch wide too in the 4x4 and ZR2.
Rear End Widths
big gear head 09-28-2012 08:28 AM
It's going to depend on how wide you want it. The X body rear ends are 60 inches wide and the 2nd gen F body rear ends are 61 inches wide. If you don't need strength you could use a G body 7.5 rear end that is 58 inches wide. The S10 8.5 rear ends have tapered axle tubes, so be aware of that.
That chart has been around for a long time and is in serious need of some corrections. The '67 to '69 Camaro, '64 to '67 Chevelle and '68 to '79 Nova rear ends are all exactly the same width at 60 inches. The chart has them all different. Also the '68 to '72 Chevelle and '70 to '81 Camaro rear ends are 61 inches wide, not 62 1/2 like the chart says.
Too Many Projects 09-28-2012 04:07 PM
I haven't found a chart for the width of the stock axle to know what I need. I see chassis engineering has conversion plates to moves springs out for wider perches. I'd like to keep the axle as narrow as possible to have more wheel offset to the outside (dish).
I thought the chart for Chevelle's was wrong, as I have a '66 and a '70. They both have '70 axles in them and I have to be careful with dished wheels on the '66 because of the increased width.
RWENUTS 09-28-2012 06:17 PM
Sorry for the confusement. I'll dump that.
Here's a long tested method for finding out how wide your 38's rearend is.
diy d e s i g n: January 2011
Too Many Projects 09-28-2012 07:30 PM
I can't find my 1020 mile tape measure either. I will be going to get the car next week. Just trying to do research on what to get early.
spacytracy 09-28-2012 10:34 PM
I used a 8" 72 mercury comet gt rear in mine. Think it was 58" wide. Used 8x16 saltflat special american racing wheels with 4" backset with 225 55 16 tires. I have about 3/4" inside and out clearance.
Too Many Projects 09-29-2012 06:22 AM
Thanks, that's good info.
Here's a pic of the car from the seller to change my "last pic".
http://inlinethumb36.webshots.com/18...500x500Q85.jpg
spacytracy 09-29-2012 10:41 PM
Great looking car! When I bought mine in 2003 for 4500.00 it was a running driving southern Idaho car. Thought I would just clean it up and drive it as an original car. First time in it I changed my mind. It felt like a truck! I now drive mine every day that the sun is out. So much more fun than original. Keep us up to date with photos as you build and hopefully it wont be a 7 year project like mine was.
Too Many Projects 09-30-2012 05:56 AM
You have a great car. I don't plan to spend 7 years converting mine but then I'm sure you didn't either. Things always come up and take time and money. I like the bumpers and running boards on these cars. Many I see don't have them. We are the home of MSRA here and have the Back To the 50's every year. They set a record attendance this year with around 15,000 cars 1964 and older on the state fairgrounds. Quite the spectacle to see...:cool:
I hear ya about riding like a truck.....I brought this back From Pagosa Springs CO last December. 1952 2 ton. This is like having NO suspension and with 6.13 rear gear it's goes a whopping 48 mph...:D
http://inlinethumb37.webshots.com/49...500x500Q85.jpg
This was my daily driver for the last 17 years. 42 years of driving some type of commercial truck. I just parked this for good 2 weeks ago. Know anyone looking for a '92 Pete ...;)
http://inlinethumb35.webshots.com/42...500x500Q85.jpg
Irelands child 09-30-2012 06:13 AM
Looking at that car, almost a shame to change it, but why not! Just makes it better.
A 9" may be overkill, the 8" is a good compromise - that is if you can find one. I 'ended up' 7-8 years ago with a 9" simply because I just could not find an 8" that wasn't so rust pitted that it was well weakened. Also, the 9" has probably many more choices of replacement gear sets.
With that blather said above, another choice is the Ford 8.8 rear ends. Very available in salvage yards. Are 56.5(Ranger p/u & early Explorer) to over 61" (Crown Vic, etc) wide, depending on the source vehicle. Many have disk brakes, gear ratios go from the high twos to the low fours. Every part is still available at your local parts store (drum brake parts for an 8/9 incher are virtually impossible to find at 'local' stores)
Dave W
Too Many Projects 09-30-2012 06:57 AM
Dave, I was thinking the same thing about the originality of it. I have been looking for a turn key rod or at least a project well along but didn't find anything that met my goals. I did find a couple that were close but I couldn't afford the 27-30k price tag...:rolleyes:
I will most likely keep all the original drive train parts on the shelf. Many of the mods necessary to rod it can be had as bolt on.
I have ample room to store stuff but I need to purge a lot of what's here now to make room. I will be working on a '67 GTO basket case over the winter to sell as a roller next spring. I also have a '69 GMC K10 that will get sold and all the extra parts I have to convert it to a Chev. Those 2 vehicles and all related parts take up the area of a 3 car garage.
I'm leaving here in about 45 minutes to go look at and, hopefully, bring the '38 home from TN. If it's not what the owner described or the pics show, I will drag an empty trailer back with me.
Too Many Projects 10-02-2012 05:07 PM
Well, that turned into a BUST. I drove 18 hrs straight thru to TN and the car is much rougher than described or seen in the pics. It's still there...:(
I'm still looking for a street rod...:rolleyes:
Leakie 10-10-2012 10:42 AM
Hey spacytracy, how are you measuring the "backset"??? I have the same width 8 inch rearend in my 37 and I have a pair of steel wheels from a Crown Vic that have 3 and 3/4 inch backspace. The tires just barely clear the frame, no where near enough for driving but they work for rollers. I was thinking I would need 3 inches or less of backspace. Maybe I am not measuring right? I thought you put a straight edge across the back side of the wheel and measured from the straight edge to the back of the wheel where it would butt up to the brake drum. Are you doing something different? If I had 4 inches of backspace I would not be able to mount the wheel because the tire would hit the frame. Thanks!
Too Many Projects 10-10-2012 01:06 PM
You're doing it right. If the tire is wider than the wheel, the sidewall bulge needs to be considered in the off set too.
