38 Chev sedan - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2006, 07:05 PM
38 Chev sedan
Hello,
I'm have just picked up the tin for a '38 Chev Sedan. What running gear would be good this body. There is no floor currently. I have a '76 Chev short box side step half ton , would the running gear be ok fo a cruiser ?
thanx in advance
Old 11-12-2006, 07:34 PM
go with a small block chevy engine like a 350 with a turbo 350 tranny and a chevy 10 bolt rear end. makes a nice cruiser
Old 11-12-2006, 10:08 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Welcome to the site triker. The drivetrain from your short box could be used for your 38. I am not sure if the rear end is the right width though. Is there something wrong with the 76? If not keep it or sell it and find a cheap running donor car with a 350 smallblock and use the drivetrain from it. To keep things simple try to find a donor car with the same width rear end.
Lots of info and opinions here. To get the most out of the site check out the Knowledge Base and use the search function for quick answers to your questions. As well check out the Project Journals for info and inspiration. There are several 38-41 Chev's being built by members of this site. Glad to have you here and enjoy the site.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 11-13-2006, 08:52 AM
The ideal drivetrain car for your 38 would be a Nova (68-74) or a Nova(75-up) or a Malibu (80s) midsize. That will get you engine, transmission, driveshaft, rearend, steering column, lots of electrical stuff and tires and wheels to roll around on while you're building.
Look for "granny" cars, mostly 4door sedans and wagons. Sometimes they're ratty looking but have low miles and have been well maintained.
Don't even think about dropping that body on late model chassis. Early body plus late model chassis equals JUNK 99 percent of the time. I know it seems like a simple simon solution but, take my word for it, it isn't and the results are often embarrassing.
If you don't have a frame it shouldn't be that difficult to come up with one.
Old 11-13-2006, 06:33 PM
running gear
thanks everyone for the info. I can build a trike witha car engine but this body to running gear will be a litle different.
Thanx again
Old 11-15-2006, 07:54 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Do you have the frame for the 38 that you can use or do you have to come up with a frame also?
Old 11-16-2006, 07:45 PM
38 chev
Henry,
All I have is tin. There is no frame or floor. I was thinking of using a 76 Chev short box side step truck running gear. I have been told that a S10 running gear would work ' but there are a few sizes of those also. I don't have any measurements for the 38 yet. Do you have any suggestions ? Remember I live in the land of snow and salt so my choices of vehicles are likely more limited than yours.
Thanx in advance
Old 11-16-2006, 08:00 PM
Lost in the 60's
Wiki Edits: 4
Well frame swaps are not easy.....but you need to measure your wheel base for the 38 as well as what track width to center your wheels up right in the fender wheels. Then you have to find a donor vehicle that has the same measurements. A S-10 may be close..... check out a early Dakota also..then the problem you will have will be the fact that the frame does not fit the car so.....that means channeling the floorboad over the frame in places. You will also have to fabricate a suppost structure for the radiator and front fenders etc as well as the other body mounts. Its not gonna be a real simple task.
Old 11-16-2006, 08:48 PM
Kwasyd's Avatar
Kwasyd
Frame ideas for your 38'
Hey...
Well I hope your build is making some progress.
I can post some pictures of my 38' to give you some ideas what I did with the chassis. I have not made up my mind regarding powertrain, and yes I have been told the same thing about using a Nova. I am buying an Ididit steering column to save some space and using a Camaro booster assy. The car has a Ford 8" and a Mustang II front end with Granada Rotors, so to buy a donor now would be only for the engine and wiring. I am not sure what the best things to do is.
Let me know and I can send you some pics if you like.
Old 11-17-2006, 04:25 AM
38 frame
Thanks people,
Kwasyd if you have time to send pics that would great. I need all os the help I can get on this one. I will send some pics of my trike with the Chevette motor.
Henry I will start to get the measurements this weekend from the 38.
Thanks
Old 11-17-2006, 08:05 AM
Kwasyd's Avatar
Kwasyd
Chassis Work
some pics.
ID:	16239   Click image for larger version
ID:	16240   Click image for larger version
ID:	16241   Click image for larger version
ID:	16242   Click image for larger version
Old 11-17-2006, 08:07 AM
Kwasyd's Avatar
Kwasyd
Chassis Cont...
more pics. cont....
ID:	16244   Click image for larger version
ID:	16245   Click image for larger version
ID:	16246   Click image for larger version
ID:	16247   Click image for larger version
Old 11-17-2006, 07:46 PM
home brew's Avatar
Here are a couple of specs I found on the net. These are not always correct so beware. The Chevy's from1937-39 have a wheelbase of 112.25 inches and the 1940 has a WB of 113 inches. This is from the carnut site.
The rear end is 54-55 inches wide from backing plate to backing plate and these cars have that width - '39 -48 Chevrolet, '68 GTO, '41 -48 Ford, '68-72 Chevelle, '55 -57 Chevrolet, 68-69 Fairlane 6 or 8, '66 Falcon, '69 Chevrolet, '67 Mustang V-8, '69 Firebird, '69 Cougar, '71 -73 Nova, '73 Ventura, '73 Mustang. I got this info from this site (it has front suspension measurements as well).
http://50chevy.freeservers.com/Suspe...tml#Suspension
Also check out this site for original specs:
http://chevy.tocmp.com/chevyresto/39index.htm
These sould be correct as they are original Chevy manuals.
Old 11-17-2006, 07:48 PM
Kwasyd's Avatar
Kwasyd
Web Sites
Great site for measurements.. thanks for passing this on.
Removing a Must. II crossmember for a 38 chev. frame ylchild Suspension - Brakes - Steering 6 01-15-2006 06:21 AM
small block into 52 chev sedan neil francis Suspension - Brakes - Steering 1 10-02-2005 08:20 AM
52 chev sedan front end neil francis Suspension - Brakes - Steering 2 09-25-2005 08:22 AM
Help with 53 chev 2 dr sedan roof chop FroFro Body - Exterior 2 05-04-2004 08:29 AM
38 Plymouth sedan body parts B-D Drag Racing Body - Exterior 1 04-02-2003 02:10 PM
