38 Chevy, centering axles - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2006, 11:41 PM
Last journal entry: dash mods
I put a TCI M11 with dropped spindles on my car.My car is still a frame and a plie of parts. I saw another 38 with same set up,welded in the stock position, but it looked like the front axle should have been moved ahead 3 inches.I was told it's just the camber(?) tilting wheel back, however it looks like crap.
Now I'm putting Chassis Engineering rear spring kit on and it bolts the axle in the stock location.I phoned CE to ask why they never made it so the axle will centre in the fender.The stock suspension had the axle ahead and not centered.CE said just move it back 3/4 of an inch to correct it.
My question is ,does anyone know how far back the axle should go?
From the measurements I take on the body and frame I guess about 1'' to 1 1/2" . I'm really disappointed in these designs and don't even get me stared on the sway bar fitting. Cisco.
Old 08-22-2006, 06:03 PM
Having NEVER owned a 38 Chevrolet ...
This is just hearsay ... but as I have heard ... the wheels were not what we called centered ... back in 1938.
I know that the lower you get the car ... the wheelbase changes ...
Hope this helps ...
Deuce ... Moderator
Old 08-22-2006, 06:22 PM
Take your tires and wheels you will be using, or close copies, and block up the body and frame at the height at which you want the car to end up. Place the wheels and tires into the wheel wells and move them around until you get them to look "right." This becomes very subjective, and what I think looks good, you may not. However, generally you do want the tires to sit pretty much dead center, otherwise you get what is shown in the pictures below.
Although it is hard to do financially sometimes, the only proper way to build a car is to have the actual final wheels and tires you will be using on hand right from the beginning of construction. Otherwise you can't set ride height and all the other variables that you must deal with.
Hope this helps.
Don
ID:	14324   Click image for larger version
Engine build ideas Rug Engine 23 12-25-2006 02:39 PM
Ford 9 inch to Chevy 4.75 pattern questions 3100 Special Transmission - Rearend 14 01-21-2006 08:29 AM
frames 37 chevy going on a 38 olds 38 old coupe Suspension - Brakes - Steering 0 05-24-2004 02:45 PM
Width on Chevy axles? Alf Transmission - Rearend 2 09-29-2002 05:42 PM
37, 38, 39 Chevy trunk hinges "Warning" Ed Baltera Body - Exterior 0 05-19-2002 05:00 PM
