'38 chevy rear springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2005, 08:05 PM
Last journal entry: dash mods
I have a 38 chevy sedan.My rear springs are good. I can't decide weither to have new springs made or take the easy road and use mine with blocks.If I have new ones made any suggestions as to what I should ask for> I'm a rooky. Thanks Cisco
Old 09-23-2005, 04:29 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
um, what are you actually trying to do? why do you want to replace your springs if they are ok?
JB
"Well done is better than well said." - Benjamin Franklin (1706-1790)
Old 09-23-2005, 05:01 PM
zonk's Avatar
Home Built Rods No Rules
Last journal entry: Home Made Sheetmetal bender plans
Are you using original or a different rear end? Might check with www.chassisengineeringinc.com
They have after market rear suspension kits.
Old 09-24-2005, 09:25 AM
I'm sorry, guess I do not explain properly ( can't type) .I used a IFS kit with 2" drop spindles. I"m using a 350/350 combo. For rear springs I'm wondering if I should use the stock springs with blocks ( ch 10 bolt rear) or buy a new rear kit. I want to lower the car and I am not sure what the car would ride like with either the stock springs or after market springs. thanks Cisco.
Old 09-25-2005, 04:15 AM
zonk's Avatar
I've used the chassisengineering rear suspension kit before, felt their springs had a nice ride. I not sure however I would think if you used the original springs depending on how much lowering block you use,you might have a harsh ride. Also if I remember right the chassisengineering setup has somewhat of a lowered stance already built in and their kits are a bolt in installation.
Old 09-25-2005, 05:13 AM
I had a few leaves that were cracked around the center pin on my 71 K5. Springs wear out over time (because of use mainly...not time) and my springs cracks couldn't be seen till I took all the leaves apart. If you are going to keep them at least pull them apart and clean them so you can see any small cracks. Then paint them up good and use a new center pin.
Old 09-25-2005, 07:42 AM
Will I ever get it done?
Last journal entry: Hood
I think the 38 had a torque tube. If so, the axle twisting action was transmitted to the transmission mount. All the springs were designed to do was hold up the car. Now you are going to have them hold up the car and resist the axle twisting on acceleration and braking. And they are almost 70 years old.
I went with a CE spring kit like zonk. The cars not done, so I can't tell you about the ride. I can tell you that the frame, measured from the rear crossmember to the ground with no body on it, was 4 inches lower with the CE kit. Plus, they gave when you jumped up and down on the frame where the stockers were rather rigid. They operated smoother. And you get modern, gas charged tube style shocks to boot.
Old 09-25-2005, 11:52 AM
Thanks guys, a kit it is then. Cisco
71 chevy truck rear end choppy71 Transmission - Rearend 14 09-23-2005 01:55 PM
i got ford parts on my chevy rear axle roy383ci Hotrodders' Lounge 0 09-11-2005 03:31 PM
Chevy II Front & Rear Springs Delirious2000 Suspension - Brakes - Steering 10 03-31-2004 02:34 PM
48 Chevy Truck rear fenders bg Body - Exterior 2 10-31-2003 06:30 AM
38 springs 38 special Suspension - Brakes - Steering 12 01-31-2003 10:18 PM
