38 ford windshield - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2009, 01:46 PM
38 ford windshield
hi there would a 37 sadan windshield frame fit a 38 ford sedan
thanks
Old 01-04-2009, 10:05 AM
Nailhead2x4's Avatar
.....they look the same although I didn't actually try it. My 38 std coupe had a painted one and I replaced it with the stainless frame from a 2 door sedan . Later I picked up a 37 4 door sedan and the frame looks the same but didn't measure it up, but my bet is it is identical.
...I'm just an old rock 'n roll Hot Rodder...
Old 01-04-2009, 01:35 PM
thanks i guess i will bring my 38 windshield frame with me to match it up with the 37 the guy has for sale ,that is if it stops snowing soon
Old 01-08-2009, 08:35 AM
Conrad_AZ's Avatar
Ya Gotta Drive Them!
Last journal entry: Moved...
Should Work
I have a '39 standard sedan, which is basically the same as the '38. I picked up a '37 windshield frame at a swap meet for $20 and had it rechromed $350.
There are some small differences - basically the location where the top and bottom frame pieces join. one joins in the middle of the frame the other joins a little lower. The '37 frame fit my '39 without a problem - other than getting the damn rubber to seal, but I had that issue with my '39 frame.
The hardest part of the deal was finding the little stainless clips that cover the join line. You can find them for a '35 - '36 but the dont fit the '37-'39 frame that well. I ended up having to narrow a pair of '36 clips to fit. Its okay but not as nice as I would like.
38 Ford S-10 frame exchange 348main Suspension - Brakes - Steering 6 07-10-2008 03:23 PM
38 Ford Slantback Frame Options??? 55chevy Suspension - Brakes - Steering 3 03-29-2007 12:51 PM
rear leaf springs 38 ford 38harry Suspension - Brakes - Steering 2 09-08-2005 04:30 PM
Windshield seal installation, 37 Ford Coupe Ted's37 Body - Exterior 3 08-14-2003 08:51 PM
