3800 GM purple wire at ICM - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2010, 12:25 PM
fast68's Avatar
likes chevy trucks & boobies
ok we have a 2000 monte carlo here we just put a replacement 4L60E in it and all that went perfectly well easy simple job and runs drives great we noticed top rad hose leaking at therm housing weak factory clamp fixed that and while we were doing that i noticed a purple wire someone rigged from the purple with white stripe wire in the ICM harness over to driver side under brake booster area somewhere dont know
anyone know what the purple and white strip wire at the ICM is for?
maybe will learn something interesting here
Old 07-01-2010, 01:50 PM
Last journal entry: Some More Roll Cage Fabrication
That is the 3X signal wire from ICM->PCM. That is 1 of 2 signals generated from the crank sensor. The 3x is for sequential fuel injection and determing which coil to fire within 120(1/6 of cam rotation) degrees of crank rotation along with calculating rpms. A car will run if the 3x signal is lost after starting but it should not start if not present during cranking(not 100% sure on that).
That is a common circuit utilized by aftermarket alarms and remote starts.
Also, don't you mean a 4T60E?
What's the proper way to wire an alternator? 70bird Electrical 18 08-14-2010 12:24 PM
How Do You Wire an RPM Switch Into a GM HEI? JohnTN Electrical 3 07-13-2009 08:03 AM
Options to wire coil & ignition module? Chief-e9 Electrical 19 03-15-2009 08:27 PM
One wire or three wire? Screwy Lewy Electrical 0 06-30-2003 04:33 PM
GM 3800 super charged Joe S Engine 18 05-07-2002 04:50 AM
