Thread Tools Search this Thread share on Facebook
  #1
Old 10-11-2008, 06:13 PM
runn141's Avatar
runn141 runn141 is offline
SB S10
3800 series 2
ive got a 97 grand prix with a 3800 series 2 v6. it will barely idle and it wont take fuel. it does this off and on if it sets awhile it might run normal for about 3 minutes down the road until starts again. i have took the air filter out and it made no difference, is there a sensor gone bad? i have no idea where to start. or does it sound like someone put something in the tank? ive never run it out of gas so i dont think it would be the fuel, i can still here the pump run.
Register now (free) or login to remove ads
Old 10-11-2008, 07:35 PM
dgcantrellsr dgcantrellsr is offline
Might be a Mass Air Flow sensor, sounds sorta like my 2000 Buick 3800 did a while back.
The tech man at the Gm shop left it unplugged until I got one, I drove it about 30 miles while unhooked. GM cost about $225, Advance Auto about $130 X-change
Old 10-11-2008, 07:41 PM
runn141's Avatar
SB S10
where about is this located on the engine?
Old 10-11-2008, 07:48 PM
joe_padavano joe_padavano is offline
While it's certainly possible for the MAF to be bad, these symptoms could be caused by a lot of things. Some will set a code, some will not. You need to have a scan tool connected and read the codes before you start spending big bucks replacing parts you don't need. Many auto parts stores will read codes for free (since they want to sell you the replacement parts).
Disconnecting the MAF will cause the EFI to default to a speed-density control logic. When this happened on my truck, I wouldn't have even known it had happened had the Check Engine light not come on.
Old 10-11-2008, 07:52 PM
66GMC's Avatar
66GMC 66GMC is offline
Get in, sit down, hang on
Last journal entry: Air Compressor / Cooling Tower
Is your Grand Prix a GTP model?
I have a 98 GTP with the same (supercharged) engine.
It would start, idle for a sec ... and then completely die.
It turned out to be some sort of ceramic resistor down low on the RH side somewhere near the front.
Apparently it has something to do with allowing more fuel delivery under boost conditions. Changed it out and it purrs like a kitten again.
(I love that car.)
Old 10-11-2008, 07:59 PM
runn141's Avatar
SB S10
(I love that car.)
mine is just the gt model, you dont know the exact name of that resistor do you? i am gonna go to the autoparts store and have them scan it.
Old 10-11-2008, 08:03 PM
66GMC's Avatar
If you think it might be the MAF ... this is what it looks like.
Try cleaning the corona wire with air intake cleaner or perhaps brake clean ... some sort of non-residual solvent before rushing out to buy a new one. (You have nothing to lose if you plan to replace it ... right?)
The MAF will be in the air intake system for sure ... usually between the air filter and the throttle body. My wife is out with the car right now, or I'd offer to pop the hood and have a look for you.
Old 10-11-2008, 08:07 PM
66GMC's Avatar
If yours is not the supercharged GTP model, I'm quite sure it won't have that resister.
My mechanic buddy explained, as I said earlier, that it is only used on the supercharged models in order to provide additional fuel under boost conditions.
Old 10-11-2008, 08:39 PM
runn141's Avatar
SB S10
carb and choke cleaner?
Old 10-11-2008, 09:23 PM
Soul_Hunter Soul_Hunter is offline
Last wiki edit: Hand cleaner Last photo:
Wiki Edits: 3
carb and choke cleaner will work, but very good IMO.
over the years i have tried many different things and the best i have found, and you may even already have it sitting on the shelf, is starting fluid.
use the straw tube from a can of WD-40, carburetor or brake cleaner to direct the stream & get close the elements. you don't need to touch them, just to be close, 1/4~1/2 of an inch is good.
it will blast dirt & oil from those K&N air filters right off.
Old 10-11-2008, 09:59 PM
runn141's Avatar
SB S10
thats funny because im using K&N filter.
Old 10-12-2008, 05:49 AM
RippinRon's Avatar
RippinRon RippinRon is offline
Check fuel pressure first. Maybe a clogged fuel filter or bad catalytic converter?
Old 10-12-2008, 01:38 PM
runn141's Avatar
SB S10
fuel filter is new, and i have no catalytic converter.i sprayed starting fluid on the maf sensor, so ill see what happens.
Old 10-12-2008, 08:46 PM
Chevrolet4x4s Chevrolet4x4s is offline
The filter oil may have gunked it up.
Shane
Old 10-13-2008, 01:38 PM
runn141's Avatar
SB S10
i have cleaned the sensor with starting fluid, so far so good for about 60 miles and no problem. i am gonna do away with the K&N filter because of this, that and i havent seen any power or mileage gain with it.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "3800 series 2"
ThreadThread StarterForumRepliesLast Post
3800 series revving up on it's own78novamanEngine1212-29-2008 05:22 PM
Rebuilding a drowned 3800 Series IIIMalibucdlEngine510-03-2005 12:34 AM
the 3800 series GM blockStudebakerBobEngine1308-11-2005 05:42 PM
Series II 3800ScuzzyTransmission - Rearend206-15-2004 10:55 PM
Is it possible to stroke a 400 more than it already is?stonedchihuahuaEngine812-22-2002 04:22 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
