383 2 bolt 1 PC vortec build. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-14-2010, 04:03 PM
Hi everyone,
Name is steve and I am a returning hot rod owner (previous owner of a 72 Buick GS and a 79' Cj5)
The car 79 Camaro (has a 305 and new vortec heads on it long story I know its bad to do it but the seller told me he had a decent 5.7 in it and he lied on all accounts)
So the 305 Slug is coming out this winter it has the heads (062's vortec heads on it curtesy of a bad head gasket)
I have a 2 bolt block out of a 97' truck 1 pc rear that is clean with all the stock roller equipment.
I want 400 HP and 425 ish torque that is reliable and streetable. Error on the 1500 - 4000 RPM rather than the 6-7K mark
I plan to use this kit -
http://cgi.ebay.com/ebaymotors/SBC-C...Q5fAccessories
i have spoken to them and right now they seem the best bang for the buck.
Does anyone know of a better place for the money?
I can run up to a 540 lift cam curtesy of these springs
http://cgi.ebay.com/ebaymotors/VORTE...mZ310264552234
1. Stock Converter on 3.73s and this power mark ok?
2. 2.02 1.60 valves? or stock 1.94 - 1.5?
3. Studs or bolts bottom and top end?
4. Stock oil pan? Will the 2pc pan work or the truck pan?
5. Can a stock Q-jet supply worthy power to my setup with a deliberate modifcation?
6. Stock HEI or MSD Mallory?
7. Camshaft 65 MPH Rpm 2850 with tires and gears.
So whats going to give me a reliable setup that I can drive and get some performance out of this slug. Also I need to error on the side of affordable and reliable instead of NOX and 4.10 gears. Hence if the HEI is fine I plan to stick with it money is available but needs to be spent in the wisest directions and please no bickering.
Thanks everyone.
Old 11-14-2010, 05:49 PM
bigdog7373's Avatar
Of course it's fast
A 355 will make 400 horses pretty easily if you build it right. I Would be scared buying a 383 rotating assembly from ebay. I'd buy from jegs or summit just for peace of mind, warranty, and the ability to return it if it doesn't work.
Old 11-14-2010, 05:50 PM
bigdog7373's Avatar
Of course it's fast
Arrrggghhh! This is a double post just worded differently!
Engine build help 383 2 bolt 1 pc crank sjkonyndyk Engine 20 11-16-2010 05:55 AM
Build a 10 bolt or 12 bolt for 450 HP ?? Blownchevelle68 Transmission - Rearend 7 05-11-2010 08:34 PM
planning the 10 bolt build up elcaminodragster Transmission - Rearend 4 11-28-2008 01:04 PM
383 Build Up sexypizzaman Engine 1 03-22-2006 09:46 AM
How would you build a 383? A 355? Vortec or package deal? Adrenaline_Fiend Engine 5 04-29-2003 07:58 PM
