383 with 63cc chambers - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2010, 10:59 AM
Im working on a 383 with flat tops. I havent decided on which heads to go with. I was looking at some 3927186 with 2.02/1.6 valves with 63 cc chammbers. How high will this put my compression at, and will I still be able to burn pump gas. Any other suggestions will be appreciated. This is not a strip car, just something I want to have fun with around town.
Thanks
Old 08-29-2010, 11:12 AM
topwrench's Avatar
Last journal entry: fish carb
Deck height?
Valve relief volume in c.c.s?
Thickness head gasket?
Old 08-29-2010, 01:36 PM
hm not kowing the head gasket thickness or piston head volume, or even if the block has been decked to "0", so that could be anywhere in the ball park of 10.1-10.8 with the rite head gaskets..so more info 4 us is needed..
Old 08-29-2010, 02:28 PM
I will do some homework and let you know. Thanks..
Ok, here's the debate of the century: 383 or 400 chevy!! Cast your vote and reason killerformula Engine 303 03-28-2013 08:08 PM
383 stroker v.s. 383 chrysler ...the end mcharger440 Engine 58 12-07-2012 08:16 AM
350 vs 383 build for performance Biscuit6447 Hotrodding Basics 20 03-05-2010 08:42 AM
.60 over 383 SBC Questions Mustangsaly Engine 8 06-28-2005 12:18 PM
rebuilding the 383...need ideas! TVR383 Engine 4 08-21-2004 10:53 AM
