Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383 Advise
Thread: 383 Advise
Old 07-20-2012, 08:35 AM
zildjian4life218's Avatar
zildjian4life218 zildjian4life218 is offline
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Originally Posted by stevens03 View Post
My transmission is a 4 speed muncie
gears are 307 i believe maybe 373
I want this engine to resemble my old 63 327
i will be using exhaust manifolds, i will get a intake with a oil fill tube, air cleaner, etc.
Would i have any problems with vortec heads, what other heads if i dont use Vortec?
Aluminum heads? Can you paint these to match block? Does it hold? Thanks
if your talking about the factory intake then no it won't bolt up to the vortec heads. You will have to look into something else. Are you using the factory ram horn manifolds?
